Assign an IPv6 address to a VLAN.
- Select VLANs.
- Select the Basic tab.
- Select a VLAN interface.
- Select IPv6.
- Select the IPv6 Addresses tab.
- Select Insert.
- Type the IPv6 address and length in the fields.
- Select Insert.
- Select Apply.
IPv6 Addresses Field Descriptions
Use the data in the following table to use the IPv6 Addresses tab.
Name |
Description |
Interface |
Identifies the address to which the address is assigned. |
Addr |
Specifies an IP address that is associated with a VLAN. |
AddrLen |
Specifies the prefix address length value for this address. |
Type |
Specifies the type of address: either unicast or anycast. |
Origin |
Specifies the origin of the address as one of the following:
Status |
Shows the status of the address and if it can be used for communication. |
Created |
Shows the time this address entry was created. |
LastChanged |
Shows the time this address entry was last updated. |
